주요 콘텐츠로 건너뛰기
Model A1989, EMC 3358. A refresh of the existing design, with updated processor options and a change to the keyboard materials. Available in Silver and Space Gray. Released in May 2019.
Mouse/trackpad freezing every 3 seconds for like half second
Hi guys,
I have MBP 2019 and if I am working mouse/trackpad freezing every 3 second for like half second - it's really annoying (specially in Photoshop). Yesterday I made update to macOS Ventura but still same issue.
Thanks for any advice/ideas.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
Hi
Have you tried reseating and cleaning the trackpad connection on the logicboard
Here’s the guide you will need
MacBook Pro 13" Touch Bar 2019 트랙패드 교체
Also have you tried a wired or wireless mouse to see if the behaviour persists?
If a different mouse works fine and reseating it doesn’t work it could mean that the trackpad or the cable is faulty and needs replacing
It could be a logic board issue but that is quite unlikely but not off the table
Hopefully this helps
Any questions please ask
이 답변이 도움이 되었나요?
점수 1
댓글 5개:
It’s probably motherboard issue as I noticed that one of the USB-C also not working :( I don’t know the history of this MBP but after issue with UCB-C I am done with this because I don’t know what else can be damage.
But thank you for answer :)
@roboscrap
Your most welcome:-)
If you wanted to you could try and fix the logicboard you could but from what you said it seems like CD3215(usb controller chips that has failed,ether that or the usb port itself
But then there the other issue to fix too
But it’s entirely up to you
I will check logic board and will see :) again thanks a lot.
@roboscrap
댓글 달기
답변을 추가하세요
Rob 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 15
전체 시간: 226
