주요 콘텐츠로 건너뛰기
9월 20일에 출시된 가장 크고 비싼 2019년 Apple 스마트폰으로 6.5" OLED 디스플레이를, 트리플-렌즈 카메라 시스템및 크게 향상된 배터리 수명이 특징입니다. iPhone XS Max의 후속 제품입니다.
163 질문 전체 보기
Speakerphone mic stops transmitting when other person talks
Replaced the port twice now. If the 11 Pro Max is on speakerphone and they are talking, if the other person begins talking at all they will cease being able to hear them until they stop talking. Have yet to find a solution to this issue.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Hi Tyler,
By 'port', you're referring the the lightning port assembly containing the lower microphone, right?
The 11 Pro Max has three microphones total; one at the bottom on the lightning port flex cable, one on the rear below the right hand camera, and one in the same slot used by the earpiece speaker.
The documentation I saw says that earpiece microphone is used for Siri; I wonder if it's also used for speakerphone calls. If that's the case and the problem, then replacing the lightning port microphone wouldn't help.
Just a thought; no idea if it's worth anything or not.
P.S., another article mentions that multiple microphones may be in use simultaneously for audio pickup *and noise cancellation*. Maybe that's a clue?
Does Siri work on your phone?
Siri works fine on the phone.
댓글 달기
답변 2개
가장 유용한 답변
If you have tried two different charging ports I would next try updating the phone to rule out software. If it doesn’t fix the problem the next step would be to install the logic board into another known good housing if the problem is still there it will be a board issue if the problem is solved it will be a parts issue which would point to the charging port assembly.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
There is no solution because this is not related to the phone itself, it's likely how the carrier's echo suppression is implemented.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Tested on Verizon and AT&T. Same issue. Tested with another 11 Pro Max using the same SIM and no issues.
댓글 달기
귀하의 답변을 추가하세요
Tyler Humphress 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 175
