nexus one restart interval of 10 mint
my nexus one restart interval of 10mints,what can i do
좋은 질문 입니까?
좋은 질문 입니까?
Hi there. It seems to me that your issue is likely to be ROM related. Is your nexus one rooted? If so, are you running a custom ROM such as cyanogenmod?Random reboots are primarily attributed to ROM or kernel problems. Have you installed a custom kernel?
해당 답변은 도움이 되었습니까?
I am having the a similar problem. But after extensive trouble shooting trying CM and few other roms I found the problem is hardware related.
With the nexus one switched on remove the battery cover, now but the phone facing towards you try pressing with your fingers just under the power button where the speaker is. Try pressing just around that area with your fingers around that area. You might find a spot where it will reboot every time you touch it.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,033
댓글 1개
What have you tried so far? did you try a reset? Checked your battery? Does it charge okay? Did this just start by itself or did anything happen to the phone?
oldturkey03 의
