주요 콘텐츠로 건너뛰기
A 5.5-inch smartphone by Oppo, released in August 2016. Includes a non-removable 3075 mAh battery and a 16-megapixel selfie camera. Model A1601.
Black spot on the bottom corner
My Mobile f11pro . The display was a bit loose a while ago.there are no cracks or damages on the screen.I gave my phone to a repair shop so they can apply glue and fix the loose screen but ever since that this black spot appeared on my screen. Was it caused because of glue getting between the screen or is it some other reason? my phone was not dropped down or hit anywhere as well. please help
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
I can see the screen rotating icon below that black spot. Does it prove that my display is not damaged but it is the glue that may have got in between ??
댓글 달기
답변 1개
가장 유용한 답변
Could be glue or could be dust or a moisture spot. Unfortunately you're stuck with it unless you're willing to open the phone or have the shop look at it which will cost money. Any pictures?
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Yea I have pic how can I upload it here
@geraltrivia you must add the pictures to your question. Go to edit and use this guide for that 기존 질문에 이미지 추가하기
댓글 달기
답변을 추가하세요
Geralt Liston 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 934
