MacBook Pro 2009 17' wont turn on
Hi,
I found my old mac book pro from 2009, i tried to charge it but it just won't turn on (The green led is on btw)
Any idea?
Thanks in advice! :)
Update (11/10/2022)
@danj @jmehnert is this what u guys are talking about?
Macbook Pro 17" 2009 No Power Repair on Board 820-2390
Thanks you so much for answering me!
좋은 질문 입니까?
댓글 13개
Are you using the core2duo A1297?
Jacob Mehnert 의
Until you do the test I outlined in my answer to set the direction of the failure this only one possibly! So did your system bootup or give you any reaction?
Dan 의
Sorry, but right now i'm not in the house were the computer is at.
The test you are talking about is to warm up the computer and see if it turns on or shows signs of life?
I also discovered that the mac has not installed its hard disk, but I think that even if the hard disk is not inserted it would give at least some sign of life or not?
Giulio Forchiassin 의
@Giulio Forchiassin - No, You need test if the system starts when shorting across the power pads on the logic board do you get a response? This is bypassing the keyboards power switch.
Here’s more on where they are on your system >>> Look Here - Power Pad locations for all MacBook Pro’s
Dan 의
How do I start the computer by shirting the power pads? Sorry I’m a bit dumb 😅
댓글 8개 더보기
