주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
473 질문 전체 보기
mac won't turn on or charge
hey,
I have change my battery six month ago with a iFixit kit. Everything was going well.
I am in holiday in the Caribbean, when I plugged the charger the first time (It was running out of battery), I had a very short (0,2s) green light on the Magsafe, then it stopped.
And since my mac won't charge at all (no light), I tried the different NVRAM and SMC, with an other Magsafe charger (a friend have exactly the same mac and doesn't have any problem...) - nothing.
I really don't know what to do now. Asking myself if it's a short-circuit that damaged the battery cause of the voltage difference ? Or just that my mac died on me randomly. Am pretty desperate right now because I have all my work on it.
Please, help me :)
Thanks in advance for your advise !
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
2 댓글
So the MagSafe LED just goes out? Or did it go Amber.
It lit just once very shortly, then nothing since !
댓글 달기
답변 2개
가장 유용한 답변
@jeanlecerf Unfortunately, you most likely have a bad battery (even iFixit isn’t immune to manufacturing defects). There is a known issue with the chips on the batteries board, that either needs replacing (NOT a DIY job) or a replacement battery. I had the exact same issue with a battery for a 2013 MB Air (not purchased from iFixit).
Get in contact with iFixit support about the problem. They’ll take excellent care of you :)
해당 답변은 도움이 되었습니까?
점수 2
3 댓글:
Thanks for your answer ! How did you do then with your MB ? Changed the battery?
@jeanlecerf I luckily hadn’t recycled the original battery, which was still OK-ish, so I put that back and everything was A-OK again. The supplier was out of stock on the battery, so I’m still waiting for the replacement.
Thanks you very much. I still also have my original one. I'll try when am back home. Fingers crossed !
댓글 달기
Try disconnecting the battery from the logic board and MagSafe. Press and hold the Power Button for 15 seconds. Reconnect the battery, the the MagSafe, you should get a spontaneous restart.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks. But just tried and nothing new...
댓글 달기
귀하의 답변을 추가하세요
jeannotparis 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 75
