주요 콘텐츠로 건너뛰기
Repair information for standalone freezers.
192 질문 전체 보기
freezer no running, no lights on inside or the green indicator light
there is power to the freezer but no lights inside, or green indicator light, freezer not running. could it be the main control board? its a frigidiare model fffu16f2vw
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Check outlet power or try another outlet (use a temporary extension cord).
댓글 달기
답변 1개
가장 유용한 답변
Hi @coppa
Here's the wiring diagram for the freezer.
If there's power on control board connector CN1 pins 1 & 3 then it looks like the board is faulty.
The control board (part #5304521525) has a fuse (F1) and an inrush current suppressor (NTC1) so check if they're both OK first.
If the fuse is blown then there's always a reason for this to happen and further testing may be required if a replacement fuse also blows shortly after. If the surge suppressor is faulty then it could've been due to external forces e.g. power outage surge and not something in the freezer.
The part specification information should be printed on the part itself unless if they have blown or been destroyed catastrophically there's nothing left to read on either.
Here's an image of the board showing where they're located.
(click on image)
Be safety aware if you decide to test the components. Disconnect the power from the freezer and use an Ohmmeter
If they test OK and you can't see anything obvious, post some close up images of the control board (both sides) back here. Perhaps someone else can see as to what is wrong.
기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Doug 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 150
