주요 콘텐츠로 건너뛰기
4세대 iPhone의 CDMA 버전. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. 16 또는 32GB / Model A1349 / CDMA 호환성.
295 질문 전체 보기
Water Damage (Drooled On/In) - Won't Power On
Issue:
Phone won't turn on.
Parts Tested:
Battery - GOOD
Logic Board - GOOD
HELP?:
If the logic board and battery, both tested in another device, are good - what could be preventing the phone from starting?
What happened?:
A young child got a hold of the phone. They proceeded to suck on the phone (both top and bottom). A bit after this happened, the phone died, would not turn back on, charge, etc. When the case was removed from the phone there was a noticeable amount of drool.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
SOLVED
The phone still wouldn't turn on/respond when connected via USB. I decided to inspect the dock port but before doing so performed one final troubleshooting step. I disconnected all cables with the exception of the touch panel, LCD and docking port. The phone powered on when connected via USB. Although I discovered corrosion which I cleaned on the docking port -but I found that when connecting the power cable while the phone was on made it non responsive. Although the capacitators did not seem damaged on the power cable it still did not function after cleaning. I'm confident that when I get around to replacing it the issue will be resolved.
Made another attempt at salvaging power cable. After thorough cleaning with alcohol it functioned properly and this has resolved the issue.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Supleh2 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,149
