주요 콘텐츠로 건너뛰기
Support for desktop computers by Gateway. Gateway is owned by Acer these days, and anything new by Gateway is supported under the Acer Group.
Is There An Adapter for This? Power Supply
I purchased a replacement power supply for my Gateway GT5404 tower. All the connectors seem to be there except one! I am adding pictures to show the dilemma. The connector I removed from the old power supply is marked "F2". None of the connectors on the new power supply are marked with any name.
Here is the old P2 connector:
Here is the new 8 contact connector:
Here are the new power sup specs:
Here is the motherboard info (hopefully turned the right way!):
Update (11/24/2022)
Thanks to yous guys I've got everything all plugged in and ready to go as soon as I dig up a little bit of heat sink paste! Thanks to everybody that got me on the right track!!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
For those novices, like me, following along, the 8 pin connector just slides apart to yield two identical 4 pin connectors! Voila! Problem solved!
댓글 달기
답변 2개
선택된 해법
What is the make and model of the power supply? There should be a description sheet that came with it.
What is the model number of the motherboard? It is usually printed on the board. Could be something like "Intel D945GCLG1". Might be a good idea to blow the dust off the board. Or do you still have the manual? Printed or on CD perhaps.
The 4-pin connector in the photo is like the one for the CPU.
Does one of the 4+4 connectors, in the lower left of your photo, fit? The connectors are "keyed" to certain connectors on the mother board so should be fine. Don't force anything.
When you reassemble don't forget to clean the heat paste off the CPU and heat sink and replace with fresh paste. Don't use too much. Just a "pea" size squirt will do. The force of the heat clamps will spread it around as you close it.
Let us know how it goes and don't hesitate to ask any more questions.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
I've seen this - it's not as complex as you think.
Thanks for all the info here! The second picture isn't very informative. I just took another one which shows that instead of a 4 prong power connector there is a six prong. [this should be eight prong - I can't count!!] Seems there must be some adapter out there, but I have no words for google to search them out. What would you call this connector?
No manual came with the power supply. I will post pictures of the numbers you mention above! (If I can figure out how to add more pictures somewhere here!)
I'll see if I can find that heat paste somewhere in our little rural area! Great tip!!
Seems as if I may be able to plug the 8 contact half way to one side or the other into that 4 contact socket - is that what Nick is driving at? But which side and will there be room?
Or does the 8 contact thingy break apart?
As to a manual, it is probably on the hard drive that I can't access till I get the power supply hooked up and the old jalopy running again!
댓글 달기
가장 유용한 답변
AH YES, this issue. What a lot of new power supplies do is they have a "8-pin" CPU power connector, but split it 4x4 for legacy motherboards, or 2x6 (it depends on who made it, but you see both). The reason is it's cheaper for them to do that than it is for them to sell a 8 pin version, but split the connector for legacy boards, but at the same time make it compatible with high end Xeon and Threadripper boards, which need it due to the power these processors draw. While most people will not need it, once these high end boards and processors trickle down the power supplies which have it will be required to use the boards. However, the current Xeon and Threadripper boards already demand this many pins, even today. This connector is not news to those of us who came to know it from the high end secondary market.
You see the same thing with the PCIe connector for GPUs; since most GPUs are 8-pin (except the RTX 4000 series with the proprietary 8>12 pin "high power" adapter) but you can split the 2 pins and get a 6-pin connector.
You're going to see this being a need on more and more desktops, as low end CPUs largely go to die because of smartphones and tablets, and the high end chips need A LOT of power to run. I would not be surprised if there will be a point anyone who is building a high end system will have no choice but to use a high wattage (850W+ power supply) to run some of these boards and processors!
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
My question is, Is there an adapter from the 6 pin I got with my new power supply (which was supposedly compatible with my GT5404) or do I have to do some snipping and reuse the P2 (not F2) plug from the old power supply.
BTW, what the heck is a Threadripper?? Not to mention all the acronyms you just tossed off! CPU I'm down with, but what's an EPS and a GPU?
I just want our good ol' buddy back with all our writings and photos on the hard drives!!
Seems like there should be a sweet little six to four adapter available.
@daverlea The 6/8-pin CPU wire usually splits, otherwise you only plug one half of the adapter in. You may have pins hang, but it will work.
The CPU connector is the one with yellow/black wiring only.
@daverlea There Are TONS of acronyms and abbreviations in the technology world. EPS is a connector that supplies power from the PSU (Power Supply Unit) to the CPU (Central Processing Unit) socket on the motherboard/ logic board. GPU is Graphical Processing Unit. Threadripper is a CPU from AMD (Advanced Micro Devices).
@geirandersen Yep. As these things get cheap to buy, we're going to see more people needing these 6/8 pin EPS supplies. It's when, not if. That's why I clarified where the need came from. It's already happening, slowly.
댓글 달기
답변을 추가하세요
David Rustin Lea 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 28
전체 시간: 297
