주요 콘텐츠로 건너뛰기
The selected device could not be found error on finder and itunes.
It is a 80gb iPod 5.5 gen with fat32 format. It was working prior to adding 2 songs after my mac glitched I force ejected it and now this is happening please help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hi
Have you tried wiping it using disk utility/disk manager?
When I get these sorts of errors that usually fixes it
If not try reseating the battery and hdd connections
Here’s a guide for that
iPod 5th Generation (Video) Battery Replacement
iPod 5th Generation (Video) Hard Drive Replacement
Hopefully this helps
Any questions please ask
iPod 5th Generation (Video) Battery 이미지
안내서
난이도:
Moderate
20 minutes
iPod 5th Generation (Video) Hard Drive 이미지
안내서
난이도:
Moderate
30 - 50 minutes
해당 답변은 도움이 되었습니까?
점수 2
2 댓글:
Disk utility was having a rough time loading disks and it couldn't see my iPod, I don't have tools to open the device and the hard drive has a loud high pitched noise and it clicks plus it has 12 pending sectors and 146 reallocs would that be the problem?
@legperson123
Hi
Just from telling from the noise that it makes that is most likely the issue
To add to that 12 pending sectors is quite a lot so replacing the HDD is probably the fix and of that doesn’t work ether a battery or a Logic board
댓글 달기
귀하의 답변을 추가하세요
Aussie Selo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 23
전체 시간: 140
