Computer shuts down when wall power is plugged in?
If the wall power is plugged in the computer will not boot up at all. You can hear the slight sound of the fans running and the indicator light is on, but know one is home. If the battery has a full charge and unplugged from the wall it will not boot up(has the same symptoms and the wall adapter).
When I let the battery run down to approx. 50% power it will boot up and all is good, but if I plug in the the power adapter it shuts down like I pushed down and help the power button on the upper rt hand corner of the computer.
This all started one morning out of the blue.
Thanks for any input you may have.
좋은 질문 입니까?
댓글 1개
I have the same issue as OP, none of the proposed solutions helped, I run a pc/laptop/tablet/phone repair shop. Here's some craziness, if you attach the mag-safe adapter backwards (well, with the cord facing you) the issue disappears (for me at least).
halokurse 의
