주요 콘텐츠로 건너뛰기
Toyota's fifth generation Pickup
91 질문 전체 보기
Why has my cruise control stopped working?
It was just fine for years, but now it's inert. Could it be the switch, sensor, cable, or what?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
What engine is in your truck? Anything else not working? Did this just start? Does the odometer work? Standard or Automatic?
I installed some led's under my t32 xtrail 2016...as well as an led brake/ turn signal trunk strip...it was all fine since my last dealership service, i realised my cruise comtrol had stopped work...the lights were installed a few months ago an I had no issues...the only thing out of the way was a spring they had to replace behind the brake pedal...after they did that it stopped working...the dealership says I should uninstall all the after market lights because of circuit overload that may cause the cruise to control to stop...I need some help plz
댓글 달기
답변 3개
가장 유용한 답변
Howie,
Going on prior experience, I'm pretty sure you need a new cruise control servo. Here is a link to one on eBay.
Frank
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Howie,
I just fixed my problem with the cruise control. I had the brake light on the dash constantly on.
I thought it was the parking brake switch underneath the dash so I disconnected it but that didn't turn off the dash light.
I then disconnected the brake fluid level indicator sensor which turned off the dash light. (I have to order a replacement brake fluid cap with the sensor built in (100 dollars))
So temporarily this solved the problem. Once the brake light in the dash was off, my cruise control worked. The parking brake still engages the brake light in the dash.
I'm just waiting on the new brake fluid cap with sensor so i'll know when my brake fluid level is low.
TJ
1991 Toyota Pickup 4x4 SR5
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
v6 3.0
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Howie Richey 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 5,707
