주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Won't turn on after replacement of battery and screens
I recently replaced the battery, display and digitizer screens on my A1489 and it won't power back up. Any suggestions / guidance will be appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
There are a lot of factors at play here so I'll throw outsome things you can try to narrow things down. Some more device history would also help (what symptoms was it exhibiting that prompted the initial repair is a good start)
It's possible it IS powering on, you just can't tell due to the screen not functioning properly. Plug it into a computer and see if it is recognized.
Check to see if the backlight is faulty by shining a flashlight at the display. If you can see an image on screen, the issue is more likely to be either the replacement screen, or a board issue with the backlight circuit.
Once you've determined for sure it is in fact not powering on we can see what might be causing that (other than a faulty battery, which is certainly on the list).
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Press and hold both the Home button and the top button until you see the Apple logo. If your iPad doesn't turn on, follow these steps to check your hardware and charge your device. You might need to charge for up to an hour. If your iPad still doesn't turn on, contact Apple Support
Regards,
Will
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Louis Lanier 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 155
