2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
856 질문 전체 보기
The touchpad on MacBook Pro doesn't work
Hi everybody ! As my title say new day new problem =)
New macBook pro and the problem after do a desoxydize ( don't know if it's the good words in english sorry ) so everything work except the touchpad i show you a picture for you so perhaps you can help me! the CLICK work well but when you want to move the "mouse" it's impossible ! THX for your help
http://www.hostingpics.net/viewer.php?id...
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Please give us the last three figures of your serial number so we know exactly which MBP you have.
의 답변
MacBook Pro 13.3"
Processor:2.26GHz Core 2 Duo (P7550 or P8400)
Serial #:W89262LZ66H
Model #:A1278
의 답변
The two pins (bottom left of the connector) seems to have a problem. What do you mean by "deoxidize" ? Did you work on this connector ?
의 답변
i use a product to clean the motherboard when she have take a swim!
의 답변
anyone to help me plz ?
의 답변
2에 댓글 더 나타내기
의견 추가하세요
3개의 답변
선택된 해법
As lemerise mentioned you have problems with the 2 pins on the bottom left of the socket/connector/header. I will elaborate a little further on the matter. The pin on the end is missing. The next one in isn't soldered to the pad on the board. The socket needs replaced or repaired. It will take someone with above average soldering skills and good optics to replace the socket/header. Repairing the socket/header, judging from the provided pictures, could be more difficult than replacing it. Since this has experienced liquid damage, it is uncertain that either will fix the problem. There could be more problems with components on the board or in the sub-layers of the board. Finding a replacement socket/header should be something that can be accomplished. The majority of the computer/laptop sockets/headers are manufactured by Foxconn, including the ones on Apple products, and are available through a number of sources. You may be better off using an external USB mouse.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
Just the trackpad can be replaced. It's Apple part number 922-9063
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Personally I had a problem with my trackpad and later found out that directly underneath is my batter. Well my battery was swelling which made it difficult to click down on the pad.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
VicenzoReturn 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 4,693
