주요 콘텐츠로 건너뛰기
다양한 주방용품 수리 안내서 및 지원.
Hand mixer stops after 5 seconds
I have a 5 speed Viking hand mixer that stops after 5 seconds. When I turn it on it goes right to top speed and then stops. When I unplug it and plug it back in it runs for another 5 seconds and stops. Hopefully this rings a bell to someone.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Did you find the cause? I have the same problem.
댓글 달기
답변 1개
가장 유용한 답변
note that there can be multiple reasons for a motor to act like that.
But in my experience. the most common one is that the brush/graphite stick needs to be replaced.
here is a youtube vid showing the proces on a generic brushed-DC-Motor
However it could also be overheating caused by "something else"
No matter what you do need to take it apart to confirm the cause,
but handmixers are usually "pretty simple devices" so it should not be too hard, just remember to take photos so you can put it together again.
Good luck!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Thomas Whalen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 20
전체 시간: 790
