주요 콘텐츠로 건너뛰기
Glitch Screen after Doing Battery Replacement
Hello, I did the battery replacement for my 5th gen Ipod video. Everything is working, except that I now have a glitch screen. A lot of colors, etc, with the text very faint underneath. I want to fix this! Again, everything else is working fine.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
@hs33 OI am really not sure about a glitch screen, but it sure sounds to me like either a bad display or a bad connection. Make sure that you have the ribbon cable is properly inserted and that the locking clasp is closed. Without that, the screen does not get a proper signal. Post some pictures of this "Glitch" so we can see what you see. 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
The display was fine until I did the battery change. I reattached the ribbon connectors as best as I can tell with the same result.
Since the batetry is actually one meant for your iPod we know that is not it. So that leaves eitehr a bbad logocgi board (failed dispaly driver) or a failed LCD dispaly. Chances are that this is a bad display. I'd replace it and re-evalaute.
Thank you for the advice. Much appreciated.
댓글 달기
Have you bought the correct battery? There are two types, fat and slim. If you have too big a battery it will put pressure on the back of the screen resulting in what you’re seeing.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
@strongbow The 30GB will fit the 60/80GB but not vice versa. It'll destroy the screen. Forgot all about it even after having done it myslef before :-)
I bought the one recommended for mine which is an 80GB. Maybe I should try the thin one? The part number on the new and old matched.
@hs33 Google the model number of the iPod and battery and see what comes up.
Will do. Much appreciated.
댓글 달기
귀하의 답변을 추가하세요
Harold 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 67
