주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
473 질문 전체 보기
How long do ifixit battery replacements last?
It's been 2.5 years since I have replaced my OEM battery with an ifixit unit and it's having issues holding a charge. This is all fine, but curious what the expected lifespan is supposed to be as the original OEM battery lasted much longer.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Usage and how to charge your battery is the biggest issue for many no matter who’s battery you buy.
As to IFixit’s batteries they generally hold up well.
COVID has messed up raw materials and manufacturing of the battery makers across the board. Many have shipped out bad batts, I know a few folks who had to shell out for a second battery as the seller offered only 30/60 days. At least iFixit offers a full year!
The best thing is to watch your cycle count and the batteries age both have limits. To extend your batteries life don’t do deep discharge events to often as they are the worse for your battery. Likewise recharge before you drop below the 1/4 point of charge. If you are not planning on using the system for a month or more make sure the battery is half charged and lastly don’t store or run the system in temp extremes! Below 40🥶 or higher than 80🥵 Fahrenheit.
To help you monitor things I strongly recommend using a good battery/power monitoring app like CoconutBattery
If you think you have an issue post a snapshot of the apps main window with the battery tab exposed here for us to see while the charger is charging.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
K B 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 27
