주요 콘텐츠로 건너뛰기
2012년 10월 23일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Apple Fusion 드라이브.
204 질문 전체 보기
Why does the bottom plate on my mac mini rub against the fan?
I've got a late 2012 unibody mac mini. Recently, the fan started making a rapid clicking noise when running. Initially, cleaning the fan and vents with compressed air seemed to help, but then the noise returned. After some experiments, I discovered that pressure on the bottom plate causes the noise; apparently the bottom plate is rubbing against the fan, creating the noise, and slowing or sometimes stopping the fan. If I turn the mini upside down or raise it off the desk, so there is no pressure on the plate, the fan seems to operate fine.
I've checked that the loop on the fan goes over the standoff screw and have removed and re-tightened the two screws attaching the fan, and that doesn't help.
I've disassembled the mini before, most recently to add a second hard drive, so I suspect that I may have made a small mistake while re-assembling it. Any ideas what I might have done wrong or what to check?
Also, until I have a better fix, is there any risk in operating the mini upside down to avoid triggering the issue?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
The fan cowling not the fan blade is being squeezed which in turn presses on the blade.
So it’s likely the fan unit is not sitting at the correct level. Take it off and check the surfaces under it as something it not correct.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
talk2dfox 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 15
