주요 콘텐츠로 건너뛰기
Repair and support for ceiling-mounted bladed fans.
33 질문 전체 보기
Do you need the exact same value capacitors when swapping an old one.
I'm looking to change of the capacitors on my fan but I could only find one's that are almost similar in rating. Is it okay to use the capacitors from this seller:
https://shopee.com.my/Kipas-Capacitor-OR...
Here's the PCB of my fan:
https://i.imgur.com/VOA3cWQ.jpg
As you can see some of the caps provided by the seller has similar voltage but different uF and vice versa. Should I keep looking for capacitors with the exact rating or is it okay to have some slight difference in rating?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Generally with capacitors the factors you most need to take into account are the type, such as ceramic disk or electrolytic, the Farad rating and the voltage rating.
Circuits are designed for a specific F rating, usually in uF, or micro Farad numbers, so that number needs to match. The voltage rating is less critical, but in order to substitute you can only go higher in voltage never lower. So if your existing capacitor is rated for, say 200 volts, it's okay to use a 400 volt rated cap, but definitely a no-no to use a lower rating like 50 volts.
That being said, the ones you've found will most likely work; most components are specified within a range of allowed variation; 20% is a common number in use. The difference between a 2.4 and a 2.5 uF capacitor is only 4%, so that falls well within a 20%, 10% and even a 5% tolerance.
The 1.6 vs 1.8 uF difference is a bit closer to a 10% variance (11%, actually), but my guess is it would probably work.
As I mentioned, it would be preferable to use the exact value as the original, but if the ones you've listed are the only ones you can feasibly get, they should work.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
zayd1009 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 70
30일 전: 315
전체 시간: 1,518
