Xbox want turn on and took it apart and cleaned it and didn't see any
Xbox one s all digital want come on or anything
좋은 질문 입니까?
좋은 질문 입니까?
Does it come on into safe mode? Hold the sync button and press (and release) the power button.
If not, have you tried replacing the power lead? I’ve seen a few faulty ones. Ask a friend if you could borrow theirs to test
해당 답변은 도움이 되었습니까?
Double check all of your connections to make sure you don't end up doing unnecessary repairs. It's easy to not plug something in right. It's not likely, but there is also a chance you could have knocked the power button off the IR blaster daughterboard. I did this during a repair, and I came to realize how easy it was to knock of the tiny little buttons. A way to test this is to listen or feel for a click when you press the power button. If it is broken, here is the part you will need to fix it: Xbox One S RF Board and IR Blaster
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 28
