주요 콘텐츠로 건너뛰기
1903년에 설립된 영국의 자동차 제조회사가 생산한 차량 수리 안내서 및 지원.
Can’t find the relay in a Vauxhall corsa E?
My blowers aren’t working in my car. We have checked the motor and that is working. The fuses are good. Now we need to relocate the relay to check that. Where would we find the relay in a Vauxhall corsa 17 plate?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
From Haynes, "... in the underhood fuse block there is a 40A cooling fan high speed relay at positions 41 and 45 and R6 , with a 30A cooling fan low speed relay at position 44 and a low speed relay at position R8". This would be fairly similar across most variants, but if you can provide an exact year, engine capacity, model number, etc to confirm? This is a common diagnosis, but the issue may instead be solved by changing the temperature sensor or repair the engine computer. Relays can be opened up and the contacts cleaned by pinching and sliding a business card through them.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Vauxhall corsa 1.4 energy ac eco flex
1398cc, 2017 plate, W0L0XEP08H6052303
댓글 달기
답변을 추가하세요
Katiejames123 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 402
