주요 콘텐츠로 건너뛰기
The first-generation Volkswagen Touareg was released in 2002 and was produced until 2010.
Rough idle reason causes
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Aweston,
That's a pretty generic question; you'll be much more likely to get a relevant answer if you can include more information, such as,
  • What year, engine and transmission do you have?
  • When did the rough idle start? Has anything changed with the car around the time the problem started?
  • Does it idle rough all the time, or is it different when it's warm or cold?
  • Is the check engine light on?
  • Have you pulled the OBD-II codes? If so, what did you find?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Aweston 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 167
