주요 콘텐츠로 건너뛰기
Samsung 65-inch 2160P TV. Released in 2015.
39 질문 전체 보기
Does anyone have any ideas?Backlight possably?
OK so my tv decided to darken most of the center of screen and the outsides became brighter but only specific parts of both sides of screen. If you look close enough you csn see what looks like an LED strip on both sides. Is this an issue with backlights or could the strips have been shifted some how? Would i replace those trips or open the hood and just readjust tthe positioning?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi @kod3rok
It looks like the LED strips or perhaps the power supply to the particular strips that is the problem.
Easiest way to tell is to get a TV backlight LED tester (examples only) and connect that to the power leads to the individual LED strips i.e. disconnect the LED power supply cable from power board and connect tester to the appropriate wires in the cable.
That way you're testing the strips in isolation i.e. no power on TV (backlight tester has its own power) and LEDs are not connected to anything else.
If they light up, it's the power board, if they don't it's the LED strips
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
this is what's happened, the LEDs have burnt the diffusion layers due to a terrible design from samsung, they should have recalled every one of them.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Erik E. Dickinson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 35
