주요 콘텐츠로 건너뛰기
천장, 상자, 타워 및 스탠드 팬/선풍기를 포함한 모든 가정용 기계 팬/선풍기에 대한 수리 안내 및 지원.
188 질문 전체 보기
When I put my fan heater at the first hot scale the fan doesn't turn
When I put my air heater on the first level of hot the fan doesn't spin but the heating coil turns on.On the second level of hot the fan spins and its all good but the problem is that i don't want it always being on the second level.This problem started lately and for the past couple of years it was all good.The haters model is:Rowenta-Mod. S06215F0 https://drive.google.com/file/d/1LdzRhU0...
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 3개
In the exterior it is a regural switch but if you want i can open it
I opened it up and took pictures of it and a video
@oldturkey03 I opened it up and took pictures
댓글 달기
답변 1개
가장 유용한 답변
@oldturkey03, My initial thought is that it probably doesn't use PWM for the fan speed. With only two or three different speeds needed, it's going to be cheaper to use a hardwired switch to change the speed rather than the electronics needed to generate a variable PWM signal. It seems to me that electrically-oriented designs (as opposed to electronically-oriented) like low end heaters tend to keep electronic components to a minimum.
It would be worthwhile to open up the heater and check the switch. I see two possibilities here; either the switch isn't directing power to the fan on the low speed, or the fan has the speeds built in and the low speed isn't working.
Vagelis, it would be useful if you could open up the heater and post pictures of the switches and the wiring that's connected to them. Also, a little clearer photo of the exterior controls would be appreciated.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
@dadibrokeit i opened it up and took some pictures
댓글 달기
귀하의 답변을 추가하세요
Vagelis 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 43
