주요 콘텐츠로 건너뛰기
2012년 6월 출시 / Core i7 프로세서 Turbo Boost 포함 / 최대 1 GB DDR5 비디오 RAM
596 질문 전체 보기
Which of the two Wi-Fi cards do I need , the 4.0 or the other
Hi 2012 MacBook Pro, wifi card which one as there’s two listed , can the 4.0 be fitted
Update (01/22/2023)
MacBook Pro Unibody (Early 2011-Mid 2012) AirPort/Bluetooth Board
MacBook Pro Unibody (Early 2011-Mid 2012) AirPort/Bluetooth Board 이미지
상품
$42.99
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Can you link which two cards you mean? And confirm exactly which model you need the card for?
댓글 달기
답변 1개
가장 유용한 답변
I see, there are two options in the drop down. If you are looking for the options specifically for the 2012 Unibody 15", Apple's technical specs list 4.0 as the standard Airport card. The same form factor is used for the 2011 and 2012 models, You can compare the number on the board to the one in your system now if you want to compare.
The 2011 model made use of the Bluetooth 2.1 card.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
That’s helped me out a lot , i have compared the old board and it’s the same as the 4.0 , thank you .I just wanted to make sure I didn’t buy the wrong one .
댓글 달기
귀하의 답변을 추가하세요
SIMON PIDGEON 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 38
