주요 콘텐츠로 건너뛰기
조이콘 컨트롤러와 약간 더 작은 스크린이 통합된 보다 합리적인 가격의 순수 핸드헬드 버전의 Nintendo Switch의 게임 콘솔입니다. 2019년 9월 20일 출시.
Why won’t my Switch Lite turn on after a shell swap?
Hello, I recently swapped out the old yellow shell of my Switch Lite for a new one. Now it won’t turn on, the screen is completely black, not a hint of light. It worked fine before. No water damage. I let it charge overnight but it still wouldn’t work. I stowed it away for later and when I pulled it out again the backside was warm. I repeated the power cycling options. Still no joy. Things that I have tried to do to fix it:
  1. Took it all apart and put it back together again to make sure every connection was snug
  2. Held down the power button for 20 seconds and then pressed the power button again.
  3. Reset my OEM charger.
I followed all the instructions from Erica Griffen’s YouTube video, even removing and re-applying the thermal paste. I’ve built PCs from scratch so I thought I could do this but I guess I was wrong. I don’t know how to do any other diagnostic evaluations. I’m wondering how I can tell if it’s a battery, MB or an LCD issue? Thanks in advance for any help you can provide.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
honestly, if it was warm, its more than likely a battery issue. Did you place metal on the battery contacts during repair?
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thanks for responding. After reading this, I installed a new battery that I had ordered. I set it to charge overnight and when I woke up this morning it still wouldn’t turn on. It’s not even warm in the back like last time. Is there anything else so can try?
a LCD replacement would honestly be my last bet, other than that it more that likely a board issue
댓글 달기
I know this is late but did you figure it out? I'm having the same issue.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sean Kennedy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 31
전체 시간: 1,029
