주요 콘텐츠로 건너뛰기
Repair guides and support for your Samsung TV.
2387 질문 전체 보기
TV not responding once on and won't turn off
I have a Samsung UN48H5500AFXZA.
It recently stopped working and I tried replacing the main board without success.
Original main board - it will turn on via remote or button. However, once on it is unresponsive. Backlight is lit up but trying to do anything (changing source, channel, volume, etc.) does nothing except the light on corner of TV will flash showing its receiving signal from remote but nothing happens.  The TV will also not even power off via remote or button.  If on, it will only turn off by unplugging.
New main board - when using remote or button to turn on, the screen lights up 1 second and then it turns itself off.  It won't stay on longer than that brief flash of 1 or 0.5 seconds.
Any ideas?
Thanks
DW
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
@dw57978 first you need to rule out your inputs as error source. Remove all of them (especially if you have some sort of cable box, sat box etc.). Unplug your TV and unplug all input sources. Hold down the power button for 30-60 sec. Then reconnect one input source (preferably local, something like Game console, DVD/BR player). and make sure you use a known-well HDMI cable, if that's how you connect. Lastly reconnect the TV and try to turn it on. See if that changes anything.
Next remove the back cover from your TV. Let's see if your power supply works. Disconnect the main board from the power board and connect the AC cable. Something like done in this video up to 0:30.
If your back lights come on you know your power supply is good. Also see if the start-up behaviour has changed. Next you need to see if it is a T-con board error. Reconnect what you disconnected first. Then unplug the T-con board (small green boar that has one flat ribbon cable going to it from the main board and two going to the panel. Disconnect the one flat ribbon cable from the main board. Behaviour changed?
Not sure why your main boards have such a different startup but we assume your new one as working order. Last but definitely not least, measure the voltages on the power board connector where the cable to the main board connects to. Let us know what voltages you get.
It will help if cour can post some pictures of what the boards and interconnect cables look like. Take one picture of all of that and then a picture of each individual board. Pst those with your QUESTION. Edit it and use this guide 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
DW57978 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 22
