주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
494 질문 전체 보기
will the battery,screen, ssd of early 2013 fit mid 2014 mb pro?
I want to know if I can take the battery,screen and ssd of a early 2013 macbook pro a1425 and install it in a macbook pro mid 2014 a1502. or if at least one of the parts will fit. thanks in advance
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
First the Early 2013 battery is likely too worn at this point (cycle count) and by its age the battery is just too old, now ten years old! You wouldn’t eat a donut that old would you? Then Apple loves it’s glue! More likely you would damage it in the process of taking it out. And lastly, this series battery is not the same as the Late 2013/2014 model.
The display is not much different! Apple altered a few things and as their suppliers also changed things to a newer interface standard the displays are not compatible either. This is the difference iDP and eDP standards.
On with the SSD, Apple uses their own interface and over time upgraded the interface and SSD. The original 2012 MacBook Pro used a custom mSATA drive Apple improved its performance a bit in the Early 2013 systems but it was still a mSATA drive! The Late 2013 models where the first PCIe Drive'd systems! So sadly this SSD really won’t work in your system besides it’s slow
So three for three! Nothing here to salvage into your newer system!
But, you can get a case to hold the SSD so you can transfer the data over or even use it as an external drive! OWC offers one.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kelvin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 28
