이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 4개
@Ahga couple of questions if you don't mind: Are you using the right ejection pin, have you tried (and successfully) opened it before, can you see any damage on the tray, is there build up of dirt, lint, etc. If you don't mind adding all that to your question that would help a lot.
댓글 4개
Colton Turner 의
Can you please share some pictures?
Electronics Boy 의
Sim card network problem
Lekhram Sahu 의
Lekhram Sahu, SIM network problem and tray stuck are not related in this senario.
Electronics Boy 의
