주요 콘텐츠로 건너뛰기
Repair information for freezers.
179 질문 전체 보기
Why is my compressor on just for a few seconds?
I bought a used freezer, and placed it on its side for transportation. I waited 24h and more before I plug it in, then I moved it a few feet in the house trying to keep it upright as much as I could, and then I plugged it.
It’s been plugged for 24h, and it’s still not working. My compressor continually starts for 3-4 seconds and then it stops for a few minutes.
The old owner says it was working well, and the light seems to be lit when I look from inside the panel, but the light bulb is weak.
Did I wait enough time before I plugged it?
Is my compressor broken?
Any thing I could do to fix it myself?
Thank you
Update (02/05/2023)
It is Danby BD100JA
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Before doing anything, ohm out the compressor at the 3 pins. Common to start, run to start, and run to common. Common to start, plus Common to run, should equal close to what start to run reads. If there's a significant difference then there's likely problems with the internal windings.
But it sounds like a start component issue, most likely. I recommend checking the start relay (Use a multimeter to test the start relay for continuity between the start and run terminals. If the start relay does not have continuity, or if it smells burnt, replace it)
After that would be the start capacitor. If you have a meter capable of reading capacitors that large then check that. You can look up the horsepower rating of the compressor using the model number on the compressor data tag. Then get a 3in1 start kit. There will be 5 wires coming out of it. The black wire without a crimped on connector that is closest to the black wire with a crimped connector would be for incoming power. Neutral goes to the other. The 3 pins on the compressor are usually labeled. And the 3 in 1 kit also shows where to hook things up.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Be certain the 3 in 1 kit matches the HP rating of the compressor!
댓글 달기
귀하의 답변을 추가하세요
Laurence 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 42
