주요 콘텐츠로 건너뛰기
iMac Pro는 Apple의 지금까지 가장 강력한 iMac입니다. 3.2 GHz 8 core, 3.0 GHz 10 core, 2.5 GHz 14 core 또는 2.3 GHz 18 core Xeon W 프로세서와 함께 제공됩니다. EMC 3144 / A1862 (ID iMacPro1,1)
iMac Pro Front Camera Showing a Green Screen
My front facing camera will only display a green screen. I have allowed all permissions, unplugged and held down the power button to have a hard restart, and tried different apps and still the camera only displays a green screen. I did an apple hardware test and it said nothing was wrong. Trying to see if there is a how-to on replacing the camera and or any other tips on how to get it working. Software: Venture 13.2 (22D49)
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
The Apple diagnostics won’t check the discrete camera elements in this case the actual photo detector (CCD).
Did you have the system opened at any point? Is possible the camera unit it’s self got damaged.
I would bring it into an Apple Store and make sure to say to them you only want someone who has been trained on this system to work on it as I’ve heard some repairs of less skilled folks talking on this much harder and expensive system.
I’ll warn you they may just replace the display assembly as the camera is part of it. Try to get it covered under extended warranty if you can. Otherwise you may just want to go with an add-on camera as that would be cheaper!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Jeff Jenkins 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 81
