replacing the internal HD
Can I replace the internal HD for a SATA2 disk?
Or it must be a SATA disk? Any SATA disk?
좋은 질문 입니까?
좋은 질문 입니까?
You're lucky as your machine does not require the new Apple firmware hard drives with temperature sensors. Any SATA 3.5" hard drive should work for you. The newer drives may need to be jumper down to 1.5 Ghz to be seen and formatted. Just do a web search for your drive and jumpers to get the correct setting.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 273
댓글 1개
I just replaced my hard disk a couple of days ago and I'm with a 'new' computer; things now are fast and reliable.
The replacement procedure is a very easy task.
sergio barrozo 의
