주요 콘텐츠로 건너뛰기
모델 A1046 또는 A1095 / 1280x854 스크린 해상도
118 질문 전체 보기
Info needed on keyboard backlighting
My PowerBook G4 didn't come with the option of a backlit keyboard, but from doing research, if i purchase the light sensors, and seeing where all the wires go, do i need to purchase a new keyboard too? I know one of the sensors plugs into the keyboard, and i have that plug on my keyboard. So will the keyboard on mine still light up?
My PowerBook is the A1095.
PPC G4 1.33 GHz Late 2004 model 15 Inch.
Mine isn't the later 2005 model. Mine still takes the DDR 2700 ram vs the newer DDR2 ram.
this is the specs from the system profile...
Model Name: PowerBook G4 15"
Model Identifier: PowerBook5,4
Processor Name: PowerPC G4 (1.1)
Processor Speed: 1.33 GHz
Number Of CPUs: 1
L2 Cache (per CPU): 512 KB
Memory: 1 GB
Bus Speed: 167 MHz
Boot ROM Version: 4.8.6f0
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Actually there are two other components that are needed. In addition to the keyboard the upper case is different. The upper case has the fiber-optic ribbons which allow the keyboard to be backlit.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
More info needed.. Depending on the PowerBook you have..
PowerBook G4(15-inch1.5/1.33GHz) & PowerBook G4(15-inch1.67/1.5Ghz) like Joe mentioned, is actually backlit via fiber optics on the top case..
PowerBook G4(15-inch Double-Layer SD) Has The lights in the keys like MacBook Pros
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
matthewfrey, mine is the first one you said. PowerBook G4(15-inch1.5/1.33GHz)
댓글 달기
귀하의 답변을 추가하세요
thereddrag0n 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,255
