Why is my phone just black?
i droped my phone it didnt crack but its just black and ican hear the notis and the calls whats the problem ?
좋은 질문 입니까?
좋은 질문 입니까?
Hi REjan ronaldo,
It sounds like everything on the phone seems to be working, but you just can't see anything on the screen, is that right?
Chances are pretty good that the OLED display got damaged in the fall. The OLED display is actually a separate layer behind the glass on the front of the phone, and it's entirely possible for the delicate electronics on the OLED sheet to be damaged without seeing anything wrong with the front digitizer glass.
I'd say your best bet for getting your phone working again would be to replace the screen. iFixit has a guide that gives step by step instructions for doing that repair.
iPhone X Screen Replacement - iFixit Repair Guide
You can find replacement parts on all the major suppliers like eBay, Amazon and AliExpress; do a search and pick the one that suits you. For those screens you have three choices on aftermarket displays:
You will need to transfer the front earpiece assembly from the old screen to the replacement. Be very careful with both opening the phone and removing this part, because if you damage it your Face ID will be disabled and cannot be fixed once that happens unless you take it to Apple and pay them to replace the screen.
Also, have at least a couple of sheets of precut adhesive on hand to resecure the display to the phone. They're kind of easy to mess up, and having an extra means you won't have to wait to put your phone together while you reorder if it goes wrong.
Always follow the guide and disconnect the battery as the first step, and make reconnecting the battery the last step. Bad things have been known to happen when connecting and disconnecting the screen with the battery plugged in.
That should get you going; let us know how it works out for you.
해당 답변은 도움이 되었습니까?
This still sounds like it’s display damage to me if it occurred at the same time as a drop. Damage isn’t always visible. It may also be difficult to see. Give it a thorough inspection with good lighting. You might se damage you couldn’t otherwise.
I will also mention the iPhone Black Screen troubleshooting page. It has some more details and lists a host of different causes in the case that the display isn’t the issue.
해당 답변은 도움이 되었습니까?
There is a known issue with iOS causing black screens. Before you order a screen press and release volume up then volume down. Then press and keep holding the power button for 30 seconds or until a apple logo appears. If it turns on check for an update. If there is one then update your phone. Had two in work today with the exact same problem.
해당 답변은 도움이 되었습니까?
Thanks Nigel; I hadn't heard of this one before. I'll keep it in mind for black screen issues in the future.
hello Nigel this is helpful but my volume up buton is not working ????
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 49
