Doesn't stay at temperature long enough.
At first I noticed while steaming milk, the temperature ready light would turn off before I was done. To get around it I just turned off the steam, waited for it to get up to temperature again, and then resume.
This issue got worse over time.
Now when I brew shots the ready light turns off before the shots are even finished. I had stopped using this unit for years as a result.
Working on a different issue today I either broke and lost or suddenly discovered that the L-spring is missing from the portafilter.
Before I order a replacement spring I was hoping to have a plan for the temperature issue.
좋은 질문 입니까?
Reviewed sidebar questions? There may be deposits clogging/blocking water flow in the heating system requiring periodic demineralizing to dissolve them.
F Dryer 의
@notbroken I did descale, and I'm waiting for the replacement spring to re-test.
I did see someone respond to a similar question saying that the ready light turning off is normal when drawing shots. I just don't remember that happening before.
Stan Landers 의
@vauweh this should be right up your alley of expertise. @stanl do you have a model number or any other identifier for this machine?
oldturkey03 의
It's actually an Estro Vapore from back when Starbucks first started selling Saeco machines, but before they started rebranding them as Baristas.
Stan Landers 의
What year was the unit built? Issue sounds like electrolytic capacitors in / near the temperature sensor.
Barrie 의
댓글 4개 더보기
