주요 콘텐츠로 건너뛰기
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
207 질문 전체 보기
At the 19 second Mark the drum tends to just Tick Tock back and forth
After the washing machine fills up and drains then at the 19 minute mark the drum tends to tick tock back and forth and does not progress any further than that
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
While I am far from an expert at home appliances it sounds to me like the drive belt is slipping. You can attempt to follow the Maytag Bravos Drive Belt Replacement to assist with the replacement. But I am sure someone else with more expertise should be able to add on.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
@davidleacock besides the excellent answer given by my colleague @thequacker I suggest that you run the diagnostic tests and see what, if anything, pops up. Here Maytag Bravos Quiet Series 300 Tech Sheet is the tech sheet for your washer. It'll tell you how to run those test. One may want to allow the automatic test cycle to complete prior to going into specific troubleshooting tests. So, start with that.
댓글 달기
귀하의 답변을 추가하세요
David W Leacock 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 25
