주요 콘텐츠로 건너뛰기
The Bose Wave Radio AWR1-1W, also known as the Bose Wave Radio I, was released in 1993. A countertop AM/FM radio system with a high performance stereo tuner and two independent alarms.
37 질문 전체 보기
Suddenly no sound, everything else looks normal
This morning I went to use my Wave as usual. After about 5 seconds the sound cut and I can’t get it to come back. Everything else looks and functions as normal. Any ideas what component suddenly died and how to fix it? Bose are no help … thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
@bmort time to take it apart and see what may have failed. Look for components that may have overheated, corroded or otherwise look damaged. Of course, make sure that all your "external stuff" like volume, connections etc is all still properly connected and set Bose Wave Radio AWR1-1W Repair
Yes I'll take a look inside to see if anything is visually damaged. I've heard the battery can leak onto some important wires over time. If that's the cause of the failure I wish they'd not bothered to put a battery in the first place...
댓글 달기
답변 1개
I think it's problem of thermal shut down by amplifiers chip
Keep in air circulated space amd try
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
It's currently about 12 degrees celsius in the room where we use this and nothing over the vents so think that temperature shouldn't be an issue :)
댓글 달기
귀하의 답변을 추가하세요
Ben 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 36
전체 시간: 254
