주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3520 질문 전체 보기
Why does my iPhone say no service after I insert my simcard
My iPhone 5s is saying no service after I inserted my sim card
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
Hi
Have you considered that the phone could be carrier locked?
This means that it can only use certain SIM cards from certain carriers
If you can find out who it’s locked to you might be able to have it unlocked :-)
댓글 달기
답변 2개
가장 유용한 답변
If your iPhone 5s is saying "no service" after you've inserted your SIM card, there are a few potential reasons why this could be happening:
  1. SIM card is not inserted properly: Make sure that your SIM card is properly inserted into your iPhone's SIM tray. You may need to remove and reinsert the SIM card to ensure it is seated correctly.
  2. Network issue: It's possible that there's an issue with your carrier's network. Try restarting your iPhone, or contacting your carrier to check for any network outages or service issues in your area.
  3. Software issue: Sometimes, a software issue can cause your iPhone to display the "no service" error message. Try updating your iPhone to the latest version of iOS, or resetting your network settings by going to Settings > General > Reset > Reset Network Settings.
  4. SIM card problem: If you've tried the above steps and are still experiencing issues, it's possible that there's an issue with your SIM card. Try inserting the SIM card into another phone to see if it works, or contacting your carrier to see if there's an issue with your account or SIM card.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
don't forget an issue with the SIM card reader on the logic board.
also, if the phone is network locked, that the SIM card is for that company's network.
댓글 달기
Also check the IMEI online to make sure it's not blacklisted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
islahu6 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 64
7일 전: 377
30일 전: 1,575
전체 시간: 6,396
