iPhone X stopped charging suddenly
My iphone X stopped charging suddenly last week. I've tried different cables, different chargers. I even tried to do a hard reset without any results.
좋은 질문 입니까?
좋은 질문 입니까?
hello Dr Bob,
what happened to the phone before. A fall, maybe a previous repair... it all matters. Check a induction charging.
any way, charging problem is connected with many problems. For user, checking and fault seeking have beginning and an end in lighting cable/wall charger. THe rest of stuff is inside. Finad a proper repair schop and ask for diagnosis.
You don't need to order a repair if you want to save money. The diagnosis will lead to the discovery of the fault, and on this basis you make a decision. In this model, the charging port is most often damaged (which you can replace yourself), but also a problem can be the connection of the motherboard or the charging system itself. I suspect you're not a micro-soldering expert. In this case, trust the specialists.
해당 답변은 도움이 되었습니까?
Hi
When a charging port randomly stops working it’s usually one of 2 things
A hardware failure as @tojaert has mentioned,that will need a part replaced what ever that may be
Or
It could just be just be dust and debris stuck in the charging port,this can be resolved by getting a very thin sewing needle or some fine tweasers and carefully removing the debris with the needle/tweasers
When I do this I usually finish it off with a very very small amount of isopropyl alcohol and a tooth brush
I recommend doing this method under a torch so you can see what your doing better:-)
Hopefully this helps
Any questions please ask
해당 답변은 도움이 되었습니까?
yes, You right - it may be that too. Thank you for adding and completing @hellomacos
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 41
