주요 콘텐츠로 건너뛰기
Model A1318 / 32 or 64 GB capacity
299 질문 전체 보기
Why won't my iPod Touch Turn on?
OK, I'm fairly knowledgeable about iPods and iPhones as I repair them and such. I recently bought an iPod that can't turn on at all. I have Tried plugging the iPod in with 4 different power cords to 3 different PC's. I could not get it to turn on, I have tried the simple Hold Power and Home Button trick as that did not work. At first I thought this iPod was in DFU mode as in that mode you usually have iPods not turning on at all at that state unless you restore or used iREB. Well, could it be the charging port dock issue? I could repair those and de-solder and re-solder new ones, would that fix the problem? Or replace it with new battery?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
The logic board is most likely not detecting power. But, start with the cheapest thing first the battery. Replace it first, and if that doesn't work replace the logic board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ahsan Qureshi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 1,128
