Why doesn't my MacBook Pro early 2011 turn on and display?
I have a Macbook Pro Early 2011. It doesn't turn on to display when i switch it on using the power button. But when i plug in the charger it turns on automatically but doesn't still display. When I opened the back cover and i plugged it in, the fan started spinning, slowed down a little bit then continued spinning. This happened repeatedly. I put my ear close to the CD-ROM and found out that the same thing was happening but it was more like would start and then stop then start again then stop. I have tried to reset the PRAM and the NVRAM but it doesn't still turn on to display. As all these happens, the sleep light turns on and off repeatedly and the keyboard light does not turn on at all. I read somewhere that i should try disconnecting each of the connectors one by one until i see a different behaviour but it didn't work. I tried disconnecting the battery which seems to have an issue because it doesn't charge even if i leave the laptop plugged in, when i do, the fan starts spinning then stops completely then starts again and this goes on and on. Please what may be the problem 😩. I need the laptop to work ASAP.
좋은 질문 입니까?
