주요 콘텐츠로 건너뛰기
Released in May 2020, the 13" MacBook Pro features quad-core Intel 8th generation Core i5 and i7 processors, and Intel Iris Plus 645 integrated graphics. (Model A2289/EMC3456 with two Thunderbolt 3 ports)
71 질문 전체 보기
Won’t boot after trackpad replacement
My MacBook wouldn’t boot into normal OSX always in safe mode with trackpad and keyboard not working…replaced trackpad. Will power up now but immediately shuts down. Any ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
I would see what the onboard diagnostics tells you. Restart your system and press the D key to enter. Let us know what the error is. If needed use a USB keyboard if yours fails to respond.
해당 답변은 도움이 되었습니까?
점수 0
댓글 9개:
So do I just press D key on boot? I’ll use my usb keyboard thanks so much
I tried several combinations didn’t work….will display logo but then shuts down without booting.
@michaelgruhlke - Is the charger plugged in so the system is powered? Is it the correct charger and cable?
Hello…thanks. Yes I’m using the apple charger and cable that came with the laptop; wondering if the ribbon cable not fully connected? Should the connection at the trackpad show any metal? I have a 2020 MacBook Pro two thunderbolts A2289.
댓글 4개 더보기
댓글 달기
귀하의 답변을 추가하세요
Michael Gruhlke 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 98
