주요 콘텐츠로 건너뛰기
Repair information for freezers.
179 질문 전체 보기
My fridge doesn't stop running even if it hits its the ta temperature
I have a VENDOMATIC freezer from 1980 and when i plug it in and set the temperature i want it to reach it doesn't stop running even after a long time
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
3 댓글:
Hi @vagelis48076,
What is the model number of the freezer?
What is the actual temperature in the freezer shown by a thermometer that is placed inside the freezer, just in case the temp gauge on the control panel is incorrect?
@jayeff
Heres a picture of the model number
https://drive.google.com/file/d/1Ul2Up_5...
I will try putting a thermometer like you told me but if you see in the picture I can't set the exact temperature that i want i can only twist the nob
@jayeff
I put a thermometer in it and it sows the temperature that it is supposed to and when it reaches the temperature it cuts off the only thing now that is wrong is that the alarm light is on
댓글 달기
답변 1개
@vagelis48076
I can't view the link that you posted as I don't have access.
Post the image of the model number in your question.
Here's how 기존 질문에 이미지 추가하기
You may have to work out what the set temperature is for both Normal - min and max and Super - min and max settings by using the thermometer and checking what the temperature is for each setting when the compressor stops running because the set temp has been achieved i.e. normal min temp, normal max temp, super min temp and super max temp. At least you will then know the temp range for both settings Normal and Super.
Once the model number is known, hopefully the user manual can be found and that will indicate what the Alarm means
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Vagelis 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 26
