주요 콘텐츠로 건너뛰기
Apple의 2016년 개정판 노트북은 전문 사용자를 대상으로 제작되었습니다. 15 인치, 2880 x 1800 Retina 화면, 쿼드-코어 Intel Core i7, 256 GB / 512 GB / 1 TB / 2 TB 저장 공간 옵션, 16 GB RAM, 그리고 Touch Bar가 장착 된 키보드가 특징입니다. 2016년 11월 출시되었습니다. 모델 A1707.
259 질문 전체 보기
Won't sleep when lid is closed
Hi everyone,
When the lid is closed on this MacBook, the laptop doesn't go into sleep mode. This happens whether it is plugged into the charger or not. macOS has been clean installed and that has not helped.
I believe that it is very unlikely to be software related at all, so I would like to know what parts of the MacBook can cause this. I assume there is some sort of H.A.L.L effect sensor in the top case, but would replacing the top case resolve this issue? (the battery needs to be replaced too so it isn't too bad to do this at the same time.
Thanks, Philip
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Yes your system uses a Hall sensor with a magnet imbedded in the displays lid. The Hall sensor is hidden in the Right side speaker MacBook Pro 15" Retina (Late 2016-2017) Right Speaker
Replacing it should resolve things. But to be sure use a rare earth magnet sliding it along the face area of the speaker area the display should react if not that’s your problem.
MacBook Pro 15" Retina (Late 2016-2017) Right Speaker 이미지
상품
$24.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
thank you. will check that out.
댓글 달기
귀하의 답변을 추가하세요
Philip Race 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 46
