주요 콘텐츠로 건너뛰기
Repair and disassembly information for Samsung's flagship S21 Ultra Android smartphone, released in January of 2021.
48 질문 전체 보기
S21 ultra not recognizing usb device's
Why does my galaxy s21 ultra not recognize usb device's for file transfer or wired ear phones
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hello,
Try taking a look at the settings. I believe there is a security setting for external devices. Try looking inside the privacy and security settings. If there are no settings causing this issue, there might be a issue with the USB C port. I hope this helps!
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
If I plug my tablet into my phone using the factory type c to c cable it allows me to charge my tablet but no file transfer
You need to activate developer options. You can do so by going to your settings-about phone-software information.Click on build number 7 times. This activates developer options. Go back to settings and scroll down till you see developer options then click on it. Scroll down till you see options for debugging. Click USB debugging to turn it on. This should allow you to transfer using your C to C cable.
댓글 달기
귀하의 답변을 추가하세요
timothy walter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 27
7일 전: 128
30일 전: 637
전체 시간: 4,264
