주요 콘텐츠로 건너뛰기
The Meta Quest 2 (formerly Oculus Quest 2) was released in October 2020 and is the successor to the Oculus Quest.
Is it possible to replace the charging port for the oculus quest 2
my charging port is broken and i have a bunch of friends on there and i love the quest 2 but its breaking the reason why the port is breaking is because i usually play while its charging meaning that its breaking it
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 달기
답변 1개
선택된 해법
Hi Jack,
Yeah that part is definitely fixable; the good news is that it's a separate cable that incorporates just the headphone jack and the charging port so there's no soldering or specialized skills required to replace it.
Rather than repeat an entire answer, I'm just going to point you the the previous question where I responded with exactly the information you are looking for.
Can you fix the part that charges a piece is broken in it . - Oculus Quest 2 - iFixit
Sounds like you'd do well to pick up a couple of spares when you're ordering that charging port!
Good luck; let us know how it goes.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Thank you i thought that it would always be broken that just continued my yt gorilla tag channel
@jackmeren Excellent, hope you get it going again.
BTW, you might consider one of those charging cables with the magnetic head to use while you're playing; that way if you hit the cable it'll just pop off with no damage. Here's an example of the kind I'm thinking of.
https://www.aliexpress.us/item/325680153...
댓글 달기
답변을 추가하세요
Jack Meren 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 22
지난 30일: 109
전체 시간: 13,991
