주요 콘텐츠로 건너뛰기
2010년 중반기 모델 A1278 / 2.4 or 2.66 GHz Core 2 Duo 프로세서
787 질문 전체 보기
Can I replace the ZIF locking flap for the keyboard ribbon cable?
I unevenly applied too much pressure on the cable retaining flap of the ZIF socket and half of it broke off. Can I replace the little flap or is there a tip to make sure all of the keyboard contacts are made once the ribbon cable is connected? Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
선택된 해법
You cant not replace it, but i would suggest using masking tape(the not so stick white tape) and use a small piece of it to hold it down, or you could use sports tape like lacrosse tape, etc... it will work just as good. DO NOT USE GLUE!!!!! If you use hot glue it could ruin the cable etc, super glue you will never be able to take it apart again if you ever need to, and regular glue is just too bad to use. Hope all goes well, the tape should do the trick.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
We replace ZIF locks all the time at my shop. Finding the replacement part is the hardest part. It's not easy but it can indeed be replaced.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
can you tell me the name of your shop and how much you charge
댓글 달기
I'm unsure if it's against the forum rules for me to post that info or not... feel free to send me a message here or an email to tlctechvending@gmail.com
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
bodkincreative 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 5,001
