메인 콘텐츠로 스킵하기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
596 질문 전체 보기
liquid spill. keyboard not working, replacement
I need to replace the keyboard, i have the tool kit bought and the keyboard but can't find the actually guide? any help please
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
3개의 답변
선택된 해법
This usually requires replacement of the whole topcase. You can use this guide: MacBook Pro 15" Unibody Late 2008 and Early 2009 Upper Case Replacement Here's a video on it: http://www.powerbookmedic.com/manual.php...
Here are the parts that will work, for some reason unknown to me, the last number gives better price results. 661-5244, 661-5481, 661-4948, 661-5854
해당 답변은 도움이 되었습니까?
점수 4
의견 추가하세요
you can replace the keyboard just follow the directions for removal of the superdrive than the logicboard, then you should remove the backlight film which is the black plastic layer which is in place using adhesive then remove the keyboard which is screwed in with 50+ tiny screws
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
If you're right and you can replace the keyboard by itself without replacing the entire top case, then where do you buy just the keyboard?
The only parts I have found are the top case assembly only and I cannot find just the keyboard. It seems ridiculous to have to pay $275 to replace the entire top half of the laptop case for a simple case of water spillage which 9/10 times should only require the replacement of a $20-$60 keyboard.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
geoff hynes 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 868
