주요 콘텐츠로 건너뛰기
2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
755 질문 전체 보기
Disc drive won't let me put a disc in, nothing in there
I can't put a disc in, there is something blocking me from putting one in, right at the front, and there isn't a disc in it - i have tried rebooting, restarting, ejecting (even though there isn't a disc in it), etc. It did this before, and fixed itself somehow, but it's not budging now. Feels mechanical, like some part of the eject mechanism is stuck on eject and not going back in???
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 17
2 Comments
Did you have any luck on this issue?
I changed my car recently away from skoda I would prefer a skoda but you can't put in a music disc into the skoda cars a comment would be welcome
댓글 달기
답변 13개
선택된 해법
If you are unable to push the disc in at all then it certainly does sound like a mechanical issue. It sounds as though the mechanism that stops you from inserting a disc when another disc is present has come loose. I would recommend replacing the drive rather than trying to repair it, but it may be worthwhile removing the superdrive to take a physical look to make sure nothing has sneaked its way inside.
Hope this helps,
Wes
해당 답변은 도움이 되었습니까?
점수 3
15 Comments:
I would recommend everyone to try my hint before replacing it. It worked for me so... Just in case... :)
Sometimes the wrong answer gets accepted.
I can insert the Dvd but it pushes back out instead of running it in..
I tried inserting the dvd (elder scrolls online) but the mechanism just won't work.
Gabriel Mattos has the correct answer. Not just remove the drive. The tray mechanism is stuck. To force eject a disk that is stuck, open TERMINAL in the UTILITIES folder of Applications inside FINDER. Run this command no parentheses (drutil eject disk) but if there is NO DISK and you can't push a disk in, put in (drutil eject tray). Note that you may have to do it several times, up to 20 Ive heard. For me, 2-4 usually works.
10에 댓글 더 나타내기
댓글 달기
가장 유용한 답변
Guys,
I have solved this problem by simple running this line on terminal:
drutil tray eject
Hope it works.
PS & 1st UPDATE (18/10/2016)
So... I had the same issue again and I wasn't able to solve it right away. This time I've had (like some of you guys) to run the command several times. I ran it for like 20x before it finally wake up the drive and release it.
해당 답변은 도움이 되었습니까?
점수 80
99 Comments:
omg that was beautiful!
Thanks Lucille. I was actually quite surprised it took only this. Do hope it works for everyone else. :)
Hero. Thanks a lot mate!
You're welcome, bro! :)
Thank you!!!! Worked like a charm!
94에 댓글 더 나타내기
댓글 달기
Press and hold the mouse or trackpad button down when you power it on and keep holding it down. This forces a disk eject, or at least tells the mechanism to to go through its eject cycle. This may move the mechanism to it's fully open position for you.
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
The button reboot worked for me after the Terminal command didn’t. On PowerBook g4 2005 Leopard
댓글 달기
There are sometines screws on the top of the unit that are to be taken out before installing. It's usually clearly marked to take them out but possibly the label was missing when the unit was installed
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Restart, hold eject and when you hear the noise of the drive opening sneak a disc in.
댓글 달기
I find this is due to iTunes failing to unmount the disc or something, even after it successfully ejects it. Thereafter you need to reboot in order to insert a disc. My workaround: quit iTunes before ejecting a disc. then Eject via finder. The restart iTunes. Disc loads no problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have a HP 'puter with a 'Tower' ,. One CD/DVD disk drawer would not open when button was pushed. Go to 'COMPUTER' and click on it and a selection of various drives will appear on your 'puter. EXP~~ A drive, B drive, C drive etc etc. Determine which drive icon will not slide out and RIGHT click on the icon. A box drops down . Select 'EJECT' and it should open with ease.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Solved: Just press Eject button for 10-20 Second until "CD In" disappear. That is it. Don t make it complicated. It worked for me
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
That's wonderful, Amir.
댓글 달기
just remove the sata/ide cable then press cd/dvd drive open button
thats will worked for me.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
this is happening to me too! GAHHH! so annoying. so i tried the terminal thing and i just typed drutil tray eject a bajillion times. each time it made a different noise but after i typed it twenty or so times it stopped and still wouldn't let me put the DVD in. i have a pretty old macbook but i feel like at least something should solve this problem!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have tried this hundreds of times but it never worked for me either!
댓글 달기
I tried this 30 + times but it didn't work. Bought an external drive now!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have an external drive that has the above problem. So: no disk in drive, drive unplugged: I gently tapped the drive on the desk with the opening DOWN about five times. Then I dragged a SMALL nail just past the opening to try and pull out anything that may have been dislodged. Nothing came out. So I did it again. Still nothing came out. So I popped a disc in that I didn't care about into the drive and BINGO... It accepted it!
Hope this helps someone. - Lindy
PS: Hope this didn’t enter twice as I had to sign up before I could comment ;-)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I tried every to take apart and visually inspect my iMac nada good idea. after 2 hours and a whole lot of frustration I opened Terminal and entered a new command this - drutil tray eject - as suggested. 20 seconds later I was free at last. Out popped the unreadable disc. It didn't even show up on my desktop. Wowee. Thank you, thank you.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I tried everything and nothing worked. I found the answer in the comment section by dewolfeinsheepsclothes. Restart the computer. While restarting hold the eject key (Top right on mac). Hold until the desk top appears, quickly put in a cd. Finally after months I can burn cd’s again.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Just like all the tricks I've tried, it did not work!
댓글 달기
귀하의 답변을 추가하세요
Gillian 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 15
7일 전: 93
30일 전: 302
전체 시간: 154,971
