주요 콘텐츠로 건너뛰기
13" 알루미늄 unibody, 2.0 또는 2.4 GHz Core 2 Duo 프로세서.
573 질문 전체 보기
No image or mirror image on display
I'm replacing a screen on a badly damaged MacBook, I replaced the LCD with a few different ones, and I keep getting a mirror image or no image at all, just backlit screen. I'm thinking I need a new cable from the screen to the board or an inverter cable... I wouldn't mind buying both to try it...but does anyone know of any other issues it could be? Cables are in securely...
Where can I buy these cables from? Ebay doesn't have it, iFixit doesn't have it... any suggestions?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
선택된 답변
Check OWC
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
You could try a local AASP, an Apple Store might or might not sell you the parts, technically they aren't supposed to. The cables are going to be 992- parts, which means the old part does not need to be returned for credit, which makes them a little easier to get than, say, a logic board.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I am an AASP... and apple is backordered on the parts... been so for 6 weeks now! thats why i am looking for another route to go... any other ideas?
댓글 달기
Another place to try is LEM Swap. I've included the URL for you.
http://groups.google.com/group/lemswap
Another source is Laptopaid. Ralph
http://computers.shop.ebay.com/i.html?_n...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
you could try ebay, they might have parts, they would be cheaper there, but they might have them here, if not, there is one other website "welovemacs.com" i think it's called, but im not sure whether they have just parts, you should also be able to use a part from a 13" MacBook Pro, since it technicly is the same computer with the addition of an SD card slot. and "Pro" after "MacBook"
good luck, display parts can be a pain to find correct models, so make sure that you check before you buy anything!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ptr702 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,494
